Already using Factory Track? Novacura Flow takes your M3 further.
You've built solid warehouse operations on Factory Track. Now extend them - with visual workflow design, cross-system connectivity, and mobile apps that go beyond the warehouse. All without touching your Infor M3 core.
Inbound logistics Inhouse logistics Outbound logistics Manufacturing reporting Approvals & workflows Cross-system integration
Trusted by:
More Trafo logo
Vedum brand logo, photo Novacura
#Capabilities
Key Capabilities :
Novacura Flow is the flexible process layer that sits above Infor M3 - extending what Factory Track started and connecting it to the rest of your business.
Gear settings icon, photo Novacura
Adapt First, Build When Needed
Begin with out-of-the-box apps and tailor them to your workflows. If something is missing - create new apps effortlessly with low-code.
Workflow & Process Automation
Streamline approvals, notifications, and business processes across teams and systems - including quality holds, exception routing, and manager sign-offs.
Real-Time Data Sync with Infor M3
Two-way data synchronization ensures users always work with the latest ERP data. Every operation immediately reflects in M3.
No More Dropped Sessions
Persistent sessions, true offline mode, and automatic sync when connectivity returns. No mid-task logouts. No switching to a browser to finish your work.
No ERP Customizations Required
Extend Infor M3 functionality without modifying the core system - upgrade-safe and secure. Keep your path to M3 Cloud clean.
Connect M3 to Any System
Factory Track connects to Infor M3. Novacura Flow connects M3 to everything else - WMS, MES, CRM, TMS, track-and-trace, IoT, and 50+ cloud platforms. No custom connectors needed.
#howitfits
Factory Track handles the transaction. Flow handles the workflow.:
Factory Track is purpose-built for M3 warehouse execution - and it does it well. Novacura Flow is the orchestration layer that connects Factory Track transactions to approvals, cross-system data flows, custom mobile UIs, and real-time analytics.
#Platformoverview
A perfect mix for Infor M3:
Novacura Flow is a versatile software suite that helps extend and significantly expand Infor M3 systems. A low-code platform, a BPM engine, and an integration platform - in one.
Low-Code Application Builder
Build M3 applications visually - no coding required. Design processes in Flow Studio, connect to M3 with one click, and publish to any device instantly. Business users can adapt workflows themselves when processes change.
  • Drag-and-drop workflow designer
  • Visual process modeling — no M3 expertise needed
  • Publish to mobile, tablet, desktop, scanner
  • Your team configures it — no developer ticket required
Deep Integration With Infor M3
All applications are deeply integrated with your Infor M3 system. Every operation performed in Flow immediately impacts M3 data. Flow applications serve as an alternative, modern UI for M3 — offering seamless mobility, simplicity, and full customization.
  • Supports Infor M3 13.4 on-premises and M3 CloudSuite
  • Uses authorized APIs — respects all user permissions
  • Bulk APIs, IPS APIs, User-Defined APIs supported
  • Zero ERP modifications — fully upgrade-safe
Support For Various Devices: Mobile and Desktop
Novacura Flow brings mobility to Infor M3 systems. Applications created in Novacura Flow can run on any device - smartphones, tablets, and desktops (as a web-based application). It can even be used on barcode scanners. Our mobile user interface is simple and optimized for high-frequency use, making it ideal for tasks like reporting logistics operations.
At the same time, Novacura Flow offers a sophisticated web portal interface, perfect for presenting dashboards, generating reports, or handling complex operations such as planning and scheduling.
Real-Time Warehouse KPIs — Inside the Same Platform
Factory Track gives you transactions. Novacura Flow gives you the view above them: live dashboards for inventory status, order backlog, picking performance, and exception tracking — built into the same platform your warehouse team already uses.
  • ive inventory & order backlog dashboards
  • Picking performance & exception tracking
  • Process analytics — identify bottlenecks automatically
  • Map portlet for real-time asset and route visualization
#who
Who Benefits from Flow for Infor M3:
From warehouse floor to C-suite — every role gains something when Flow extends your M3 environment.
Operations Managers
Real-time visibility into processes and ensure teams follow standardized workflows — no gaps, no delays.
CFOs & Business Leaders
Reduce operational costs and manual inefficiencies while increasing accuracy and control across key processes.
Warehouse & Shop Floor Teams
Execute tasks faster with easy-to-use apps for picking, receiving, production reporting, and material movements — without session dropouts.
04
IT & ERP Administrators
Extend ERP functionality without custom coding — updates stay upgrade-safe, maintenance stays simple, and your M3 Cloud journey stays on track.
05
Process & CI Teams
Model, automate, and optimize business processes end-to-end — reduce repetitive work, build approval chains, and eliminate bottlenecks.
06
Project & Implementation Managers
Deploy changes quickly and adapt workflows as the business grows — without heavy development effort or consultant dependency.
#integration
Integration platform
Connect M3 to Any System. Without Customization.
Factory Track connects to Infor M3. Novacura Flow connects M3 to everything else — with 50+ purpose-built connectors to the systems your business already runs. This was the #1 reason customers moved from legacy M3 mobile solutions: they needed track-and-trace, CRM, TMS, or IoT connectivity that their existing tool simply couldn't provide.
  • 50+ connectors — WMS, MES, CRM, TMS, IoT, cloud services
  • No custom connectors or middleware required
  • Multi-language & multi-site deployments supported
  • Flow can also act as a service bus for external systems
#examples
What Flow Does in Practice:
Ready-made application packages for Infor M3 - download from the Marketplace, adapt to your workflows, and go live fast.
Supply Chain
Goods Receiving & Quality Inspection
Receive POs and DOs with full barcode/GS1 support. Trigger quality inspection workflows automatically — capture photos, assign rejection reasons, route approvals to quality managers, and generate supplier claims. All connected to M3.
Receiving Quality Approval routing IDM integration
Manufacturing
Manufacturing Operations
Report production order receipts, manage attribute-managed products, pick multiple Balance IDs in one step, and allocate materials with complete flexibility. Real-time M3 sync throughout.
Production reporting Material pick Attributes
Outbound
Picking & Shipment Loading
Flexible picking interfaces for any allocation method — consumer packs, GTIN scanning, batch picking, FIFO enforcement. Load shipments, print labels, and confirm dispatch — fully guided, error-free.
GS1 scanning FIFO Label printing Shipment
Customer Service
Customer Sales & After-Sales Service
Mobile order placement for B2C, field technician workflows for scheduled maintenance, and a comprehensive work order portal for after-sales service teams — all integrated with Infor M3.
B2C orders Field service Work orders
#casestudies
Expand Your Apps as You Wish
Infor offers a purpose-built extension to M3 that delivers strong warehouse execution. Novacura Flow was built for what comes next - connecting, automating, and extending beyond the warehouse without touching your core system.
Where Factory Track is designed for warehouse execution excellence, Novacura Flow is designed for the processes that surround and extend it:
  • Configurability: Low-code workflow design - not parameter engineering requiring deep M3 expertise
  • Extensibility: Add any logic, field, or integration with visual tools - no C# or Mongoose knowledge needed
  • Connectivity: Connect to any third-party system from within the same app - track-and-trace, CRM, IoT and more
  • Process flow: Design multi-step, multi-user workflows with branching logic and background processing
  • Scope: Manufacturing execution, field service, quality, customer portals - not just warehouse
Contact our expert:
Please fill out the form
