- Home|
- Application Managed Services (AMS) Service Description
Revision: 2025-12-01
TABLE OF CONTENTS:
1. Service Overview
This document describes the Novacura Application Managed Services(AMS) provided by Novacura AB for customers purchased AMS services.
2. Scope of Service
Customers can contact Novacura Customer Support via:
Customer Support Portal (primary channel)
The Jira Service Management portal Customer Support Portal should be used for any support needs throughout the customer’s software implementation and operational lifecycle.
Phone
This option is available for escalation of critical or high-priority incidents. It is strongly encouraged that a support ticket is registered first. Any subsequent telephone conversations between customer users and Novacura personnel will be documented in the corresponding ticket, ensuring full visibility through the Support Portal.
Supported Languages
Standard support language is English. Local languages can be provided as per separate agreement.
In addition to support, customers have access to the Novacura Community through the Novacura Forum to interact and collaborate.
3. Service Channels
Phone
Supported Languages
4. Service Hours
Novacura provides support during regional business hours Monday–Friday, 08:00–17:00 (local time, excluding public holidays in the staffed region) using a follow-the-sun model across global teams. Tickets raised outside staffed hours are queued for the next staffed region.
5. Service Levels
Service Levels for customers under AMS agreement are categorized in three different levels; Standard, Silver, Gold which sets the levels for Applications and Solutions under AMS related incidents.
Please refer to the Product Support Service Description for Service Levels regarding the Product Novacura Flow. Product Support Service Descriptions
Response time is measured from the time from which Novacura has received a Request to the point in time when Novacura starts working on the Incident.
Severity |
Initial Response Time |
Gold |
Silver |
Standard |
High |
2 hours |
4 hours |
8 hours |
Medium |
8 hours |
16 hours |
24 hours |
Low |
16 hours |
24 hours |
40 hours |
Severity |
Severity definitions |
High |
The Request is classified as a high level Incident if it results in: · The whole production System is out of use, or · Serious degradation of System responses, or · The loss of key functionality under normal conditions, or · An important System component is unusable, or · Frequent failure of an important System and Affects more than 25% of overall users and · There is no Workaround available · Business impact is high. |
Medium |
The Request is classified as a medium level Incident if it results in: · Reduced functionality due to Error(s) affecting the overall System, or · Limited degradation of System performance or random outages in the · System availability, and · A Workaround solution is available · Business impact is low. |
Low |
The Request is classified as a low level Incident if it results in: · A non-significant effect on the functionality of the System · Affects only individual users, business documents or specific, non-critical functions of the System · Business impact is low. |
6. Customer Responsibilities
To ensure efficient handling of support requests, customers are expected to:
- All support tickets should be registered through the Support Portal.
- Provide detailed information, including logs, screenshots, and steps to reproduce issues.
- Provide Novacura with secure remote access to Customer environment if required for trouble shooting.
- Ensure accurate and timely escalation with relevant details (error messages, replication steps).
- Maintain internet connectivity, client environments, and integration points under customer control.
- Stay updated on product release notes, maintenance notifications, and best practices such as coding guidelines.
Exclusions
SLA resolution times do not apply when delays are caused by:
- Scheduled or Planned Maintenance.
Downtime or service unavailability resulting from planned or scheduled maintenance activities. - Customer Systems, Equipment, or Configurations
Incidents caused by the customer’s own infrastructure, systems, configurations, or equipment. - Third-Party Vendors or ERP Changes
Issues arising from third-party vendors, ERP system changes, or other external dependencies that impact Novacura solutions. - Service Requests, Consulting, or Development Work
Requests related to consulting, customization, or development efforts that extend beyond standard support. - External Communication Failures
Service disruptions caused by failures in communication links or networks outside Novacura’s control.- Third-Party Systems and Services
Problems due to outages, degraded performance, or failures in external systems, APIs, or services not managed by Novacura (e.g., customer-hosted infrastructure, third-party identity providers, external data sources, or integrations). - Misuse or Unsupported Configurations
Incidents caused by misuse, misconfiguration, or use of Novacura products in ways that are undocumented, unsupported, or not aligned with Novacura’s guidance.
Access and Security Restrictions
Delays or limitations in problem resolution resulting from insufficient system access, restrictive security policies, firewall rules, or other customer-imposed constraints preventing timely investigation.
7. Governance & Service Management
Novacura will provide governance through SLA reporting, periodic service reviews, and continuous improvement initiatives. A Service Manager will be appointed to serve as the primary point of contact.
Change management is provided through Customer Service and will involve Novacuras Consulting department.
8. Linked Policies & References
Additional policies and documentation support this Service Description.
- Novacura General Terms & Conditions (incl. SLA definitions): Novacura General Terms & Conditions
- Data Processing Agreement (DPA): Novacura Data Processing Agreement
- Flow Connect Documentation: Flow Connect Documentation
